I came across a rather frustrating but easily resolved problem after installing my 8800GTX. After I initially installed the 97.02 driver, my performance got cut by more than half approximately. Not sure why it happened, but I reinstalled the drivers and the problem went away. I did some mild overclocking and ran 3DMark05 and 06.
So, the first set of numbers indicates the runs with the bad driver at all stock settings and the second set indicates the mildly oc'd figures and results with the good driver.
Also wanted to get some ideas from you guys/gals on my next set of upgrades. Keep in mind I'm looking for cost effective upgrades/mods seeing as how I'm still recovering from the vid card and PSU purchases. My current plans are to upgrade cooling all around, but not too sure what is best for my setup, I'm just getting into oc'ing so any advice would be appreciated.
Thanks,
ZER0
Current setup...all on stock cooling atm...
AMD Athlon 64 X2 4600+ @2.55Ghz
Asus A8M2N-LA
eVGA GeForce 8800GTX @652mhz core/953mhz mem
2-Gigs PC4200 DDR2 (Crucial Ram)
Thermaltake Power Express 250 to power the 8800GTX
3DMARK05
Main Test Results - 8800GTX
....................................(1st)...................(2nd)
3DMark Score........(5282 bad driver)......(13452 @652core/953mem)
CPU Score..............(5871 bad driver).....(6962)
Ref Clock (HTT).......................................(211.892mhz)
HT multiplier..........................................(5.0x)
CPU multiplier........................................(12.0x)
CPU core...............................................(2542mhz)
RAM.......................................................(566mhz)
Detailed Test Results
Game Tests.....................(1st)..........(2nd)
Return To Proxycon.......22.8 fps.....45.5 fps
Firefly Forest.................14.6 fps.....36.8 fps
Canyon Flight................28.4 fps.....93.2 fps
CPU Tests.........(1st)........(2nd)
CPU Test 1.......2.7 fps.....3.4 fps
CPU Test 2.......5.7 fps.....6.3 fps
3DMARK06
Main Test Results
..........................(1st).....(2nd)
3DMark Score...(2946)...(8977)
SM 2.0 Score....(1127)...(3958)
SM 3.0 Score....(1104)...(4547)
CPU Score........(1728)...(1908)
Graphics Tests..............(1st)............(2nd)
Return to Proxycon.....9.184 FPS....32.398 FPS
Firefly Forest...............9.602 FPS....33.560 FPS
CPU Tests......................(1st)............(2nd)
CPU1 - Red Valley........0.553 FPS....0.604 FPS
CPU2 - Red Valley........0.863 FPS....0.965 FPS
HDR Tests.........................(1st).............(2nd)
Canyon Flight (SM 3.0)....9.42 FPS.......49.259 FPS
Deep Freeze (SM 3.0)....12.667 FPS....41.679 FPS
PCMARK05 - 4195 (oc'd @ 2.55Ghz)
(Edit).....Figures didn't line up as well as I had hoped.....(Edit)
(Edit).....Fixed formatting to make it easier to read.........(Edit)
Thanks,
ZER0
Asus A8M2N-LA
3DMARK05
3DMARK06
Main Test Results
