You good people helped me put together my first water cooled build a couple of years back; I thought I'd share some updates. (https://www.overclockers.com/forums...t-water-cooled-build!-Please-advise?p=8088148).
I'm sure most of you already know the dangers of plexi cracking but I didn't, and this is for anyone else who doesn't know. Basically a few months ago the threads cracked on my EVO Supremacy MX and water leaked onto my EVGA 1070ti FTW2. Now, I was doing a fair bit of transporting the PC at the time, and maybe vibrations from the car's engine didn't help - or maybe I over-tightened it when refilling after a journey. For anyone considering a new water block, I'd seriously recommend either acetal or, preferably, metal blocks. I know metal is normally a bit pricey, but I managed to find a used Ek Supreme HF Full Nickel water block for just over £30 on eBay. My temps are now way better than with the Supremacy MX and there's no chance for the threads to crack. The Supreme HF is a little dated sure, but it's running nice, cool and compatible with a Z390 MB and i5-8600k, so who cares if it's an older model?
The GPU seemed almost fully dead in that it wasn't providing anything from any source, the only life it showed was through LEDs and one fan spinning up. By the blessings of the Machine God I was able to revive it back to full functionality (disassembling and cleaning it with isopropyl 90% probably helped), however, others may not be so lucky.
Other than that, I found that a noisy little doohickey nestled within (but not affixed to) my pump impeller appeared to serve no purpose.
The AA battery is only there for size reference - this is another thing that I couldn't find much info on, why it was in there and whether it might have once been attached but came loose. I wonder if the previous owner decided to sell it because one day it started sounding like a mini combustion engine. Either way my temps are great without it, previously it was making some considerable noise for about a year, rattling around in there. If anyone else has this noise issue, you may want to consider removing this piece
Hope something here helps someone
