- Nov 10, 2012
- Ankeny Iowa
I have a Phanteks Ethoo case and I am running a 480 rad up top with 8 fans, push/pull config. This is cooling a Ryzen 7900x only.
I have a XFX RX 6950 XT GPU and was thinking of putting it on water and adding a second 480mm rad in the bottom with 8 fans in push/pull config.
This is what I have up top and was going to put the same in the bottom.
GPU pulls 375 watts while gaming.
Is this doable and is my pump/res enough for both 480 rads?
