Abit it7 max2 v2.0 mod bios
Horus
im searchin for the 3.2v ram voltage mod bios
where can i get it ? :)
and is there a bios that features both , 1,85cpu and 3,2ram ?
nope. bios reads the pins on the chip to give you the apropriate voltages. you must fool the bios with the pin trick to open the 1.85 option. its easy. just follow the tutorial a the top of the page. youll be done in 30 minutes
hmm
the bios my it7 max2 v2.0 got shipped with does contain 1.85v and it's working
so why should it be impossible to include it ?
Horus said:
hmm
is 1.85 selectable? if it is then great, ive never seen this board. if not, then it needs the pin trick. let me know how things go and any thing specific to this board that needs to be done. i dont know what the 845pe chip set is capable of
hmm
Hi Horus,
Where did you get the MAX2 V2.0? Thanks.
i'm from germany
there was an onlineshop who already had it in store (the only one i found so far), seems to be located in norway
http://www.komplett.de but i dont think you want to buy there :)
and i dont think they would ship to USA
ocs really nice
but won't help you much when the cpu just reaches the end :(
