SOLVED Abit KT7A-Problems with installing games
M
Me
Guest
I have a Pioneer 16X DVD and when i install games i get errors in the install, from totally freezing up to getting an error saying the file is missing. Then if i try to install again it will work.
When i put the DVD in my other computer (celeron 300a@450 BX) it all works fine.
I have put the via 4in1 drivers on Win98SE.
Games run fine once they are installed.
Are there some settings in the bios i have to change or something?
I have it set up as secondary master and hard drive as primary master.
After i get this sorted out then i can start o/cing :)
