Hi everyone, I've been working with my new GTX 1070 through MSI Afterburner and was wondering if someone could chime in on how my overclock looks. I'm able to get +85 on the core clock and so far am up to +500 on the memory clock. It still hasn't crashed so I'll try and go higher. I do have a couple questions though:
1. My voltage is usually around 1.0830 and sometimes sits at 1.0910. I think this is the max allowed by the BIOS. Is it safe to run at that voltage?
2. What exactly do the core voltage % and power limit sliders do? I have the power limit slider maxed at 120%. What should I set the core voltage slider to? Its default is 0 and max is 100.
3. My temps max at 51C with fans at 70%. Should I turn them to 100%?
4. In GPU-z my power consumption stays below 60% of max. I thought it should be around 100%. Could someone explain why it is staying low?
Thank you for the help!
