AnEEsO
- Mar 6, 2024
Hello everyone, im new here
A while ago, I flashed my GPU bios after getting new fans for it, cause fans didn't work pretty well at first
I downloaded my GPU bios version from techpowerup, and flashed it using CMD and nvflash and it worked normally for quite some time
but like a week ago, there was an electricity power loss at my house that lasted for like 1 second, the PC booted into windows and everything was normal till I launched a game, my frames went from 200 to 15-20
I got scared and cause I didn't had that issue before I instantly tried uninstalling nvidia drivers using safe mode and DDU, did a windows format, tested the GPU on different PCs and PSU
but none of these worked out, I realized that my GPU core clock are stuck at 139mhz and Memory at 405-810mhz and tried so many things until somehow, I got the idea of testing different manufacture bios for same GPU (GTX 1080 TI), so I picked a Gigabyte this one (https://www.techpowerup.com/vgabios/203179/gigabyte-gtx1080ti-11264-180508)
and the 139mhz clock issue got fixed, but when I played I was getting way less fps and huge stuttering, I didn't find 100% fix for that, but increasing the power limit in MSI afterburner fixed my FPS and got me like 80% or more of my usual FPS
the issue that's going on now, that I have to make sure that msi afterburner is open everyime I play, and sometimes clock speed are so high when im on desktop, and GPU watt consumption is 100W on idle
I cannot take my GPU to anyone where I live cause no one has the knowledge to fix it, I hope someone here knows a fix for this and help me out with, thank you for reading and hope I hear back from someone soon
my PC specs
I7 12700k
MSI z690-A pro
32GB 3600mhz C16
850W EVGA G3 80GOLD PSU
my PC specs
I7 12700k
MSI z690-A pro
32GB 3600mhz C16
