- Apr 15, 2001
- Chicago, IL
Currently I'm running an Asus CUBX (w/CMD controller), with a pIII [email protected] (1.8v) & 256 MB of generic SDRAM (has infineon chips, however-CAS222)
I believe the CMD controller may be going bad, and I was looking into upgrading in any event anyway;
My preference has been Intel, mostly due to them running cooler than AMD rigs, and perhaps with more insurance that the chip won't be toast if the fan on the heatsink goes out.
I do use a CUSL-2 in my work/photoshop station-
Which boards would be the best to look into for a LAN gaming rig?
I'm not sure if getting the newer B-step 815 boards might be a better idea, or entertaining the distant idea of looking into the new northwood board would be better? I'm not necessarily looking to push much past 140-150 (if that) for the FSB, but I am looking for stability as well.
For cooling, I'll likely continue to use my Alpha PAL6035, it hasn't seemed to give me fits about shifting during transportation like the other HSF's I've tried.
Thanks!
Thanks!
