- Jan 31, 2003
- San Francisco, CA
hmmm.... my cpu2 is consistantly about 10 degrees celsius above cpu1. is this because my fortron ps, doesnet have the fan on the bottom??
should i try to find one with a fan on the bottom?
currently: 150 * 14 = 2100 ghz
cpu1: 57*C
cpu2: 71*C
case: 31*C
voltage: 1.66v
still testing with prime
no, i have the antec true 550 and the fortron 530 and i have tried them both in both of my dual Asus boards...
there is at most a 1 degree difference in the cpu temps when the fan is on the bottom...
i have had the very different cpu temps before (where one was 7-10C warmer than the other)....and it was one of two things:
1) too much artic silver thermal grease---needed thinner coat---as thin as possible with still a coat...
2) heat sink was on in the reverse orientation (because it was easier to put on that way)---when i put it on correctly the temps were the same...
i have also heard that dual boards sometimes report one cpu temp as higher than the other due to:
1) incorrect readings
2) higher voltage on one cpu versus the other---which causes higher temps---although 10C higher is too much higher for slightly higher voltages...
but i can tell you that the fortron with the intake fan not on the bottom has NOT made more than 1 degree higher temps than the antec truepower 550 on either machine...
