Mdameron, the caps you are referring to are the capacitors. That's not the same as power mosfets. The mosfets are small flat black square things and they do get a little warm. Up to the individual if you want to sink 'em or not, but you don't have to with a Northwood. If you have a Prescott, then I would highly recommend it.
Beginner, the OCZ Platium rev 2 RAM is a very good choice too. It's quite comparable to the G. Skill I listed as an example. The OCZ Platinium usually overclocks better than the OCZ Gold. I have a pair of Komusa Hyperram PC4200 RAM which is about the same as Adata PC4200. It's good RAM and generally will run at high FSB which is what you want for a 2.4C. The timings won't be as tight, but as long as you can run high FSB with the 1:1 ratio, that's ok.
