klosters64a (May 08, 2001 09:40 p.m.):
The Alpha PAL-6035 is not up to the task of removing 60-72 Watts of heat from a T-Bird in a timely manner. I don't care if you use an adapter to mount a 120 mm YSTech on it, the PAL-6035 can't cut it. Don't get me wrong, I love Alpha products. If you want to use an Alpha HS, the PEP-66 with a Delta from Hell-a will do the job. Not spectacularly well, but does any HSF work really well on T-Birds? The truth is that OC'd T-Birds get so hot that forced air cooling is almost at the limit of performance. Either AMD will replace the core with one that produces reasonable heat, or Koolance will get a LOT of business.
AMD knows full well that T-Birds get too freakin' hot. It's time for them to quit messing about. Replace that damn core. NOW!
Until they do, they won't sell SMP Server configs for Athlons. Folks are disappointed that they can't buy dual T-Bird mainboards yet. Don't be! 150 Watts is too much heat to deal with, IMHO.
