Antec would like to apologize for any trouble or inconvenience caused by the recent increase in problems with our SmartPower 2.0 power supplies. The problems were primarily caused by the transition at one factory to RoHS manufacturing and compliant components and one component in particular, a capacitor on the +5V standby line. There were two primary failure modes due to this: the first being lower than normal output voltages on the +5V SB line, making a good power supply appear to be DOA due to boot failure; or the second being a failure of the same capacitor after some time in service, resulting in power supply failure.
These failures under no circumstance represent any danger to anyone or to properly connected components as the power supply is designed to shut down completely with this sort of failure.
Antec has taken the most stringent possible actions to remove any suspect power supplies from our supply chain. We have corrected the problem at the factory and instituted the highest possible level of testing and quality control. We have recalled stock from our distribution partners of all production that could possibly be affected and subjected it to 100% testing. And we have subjected all of our existing and incoming stock to rigorous batch testing. Any production code which had even a single failure during batch testing was submitted to 100% testing in order to remove all possible suspect stock.
Please be assured that this problem is behind us, and no other Antec products were affected by this problem. All of our other power supplies lines—EarthWatts, Basiq and TruePower Trio—are made in different facilities and were not exposed to this problem, so you can continue to buy and use your favorite Antec cases and power supplies with complete confidence.
If you have any problems with previously purchased products, remember you have a three year warranty on all SmartPower 2.0 products. You can contact Antec Customer Support at
[email protected] and you will be provided with immediate hassle-free service to resolve your problems.
We appreciate your support and faith in Antec and our products. Again, we apologize for any disappointment we may have caused.
