No eATX support? for a case this huge?
Or did I miss that somewhere...
the one thing i dont like about my 900 is the ghey side window - this one has it too = chinstrap NOT buying and antec case again
Anyway, that case looks awesome to me (and I don't agree with the idea of the proportion tall:depth being bad, I think it gives it a more... how to say it... imposing presence -not to talk about the better airflow)
Can you tell me how a taller/less depth case has better airflow over a standard sized case? I just looked it up and guess what?
1200 (Dimensions 22.9" x 8.4" x 20.2")
cosmos 1000 (Dimensions 24.8'' x 10.5'' x 23.6'')
By my crude calculations, the Cosmos 1K is 2in bigger in height/depth/width.
Axis
In order to create the more optimal airflow, you want to use the more fans, the better. You want to have an airflow path the shorter (and more straight) the better. And you want to force the most air to pass through hot components the better.
My supplier got a shipment of these in yesterday and I popped over to have a look. The drive area has these ridiculous dividers and the fans are all part of the case!
Scratch this off as a replacement for the Stacker. It will not fit any hot swap cages or even normal multi 3.5 to 5.25 cages without some serious work. You screwed up on making a flexible case Antec!
Yep. That's exactly the reason why I said that installing a radiator in front seems to be harder than others. AFAIK (if you could confirm this...) there are 3 drive cages, each one equivalent to 3x5.25 bays, that are completely standard regarding the way of fixing to the case and so, and they could be perfectly replaced/removed, except that the front bezels, filters and fans, aren't fixed to the case, they are fixed to the drive cages, so if you want to use them, you must either use the 3 drive cages or make a system to fix them to the case or to what you're going to use. Yah, crappy design there.
I'm thinking in building a cardboard (or something) structure and use it as a rad shroud, a mounting system for the rad to fix it to the case, and a support to the front bezels, filters and fans.
And the fans themselves, I don't see they are a part of the case, they are completely removable/replaceable. The only thing is that AFAIK all fan speed controllers are part of the fan not the case, so if you use other fans, you won't have speed controllers.
