Never will I ever ever ever ever let Win 10 update again!
I enabled the 2 services that I disabled and let Win 10 download and install updates, 1) it removed openCL.dll that core 21 needs to run. 2) I had to reinstall F@H and GPU drivers and lost the WU it was working on before the update
If your PC is going to do nothing but F@H then screw the updates, not worth the headache.
Have they changed the active hours things? It was limited to 12 hours only when I looked at it.
I also stop+disable the Windows Update service (don't need to do others) to block the updating. I only turn it on after the 2nd Tuesday of each month which is when MS publishes routine security updates. It is possible to miss non-routine updates though. Also I found another side effect, that the Windows Store can't download when Windows Update is disabled. It is not important to me, as I only tried to use that once.
Some rigs need windows for compatibility and to run dedicated software. Linux is not ready for the real world yet.
So far I have found nothing but annoying problems from Linux and all its many versions. It is definitely not simple to find solutions that actually work.
I am folding on Linux but only because I can't justify $100+ upgrades for multiple rigs on windows. My experience with Linux is never to use it if I can avoid it.
I still haven't found a solution to Ubuntu 12.04 where I need multiple users to have access. It creates the users and then won't let them sign in, saying their password is wrong, even though I created them with the password moments earlier. Weeks of searching for a solution left me allowing everyone to log into my main user account so they could use the computer. Fortunately the users are ignorant of Linux and don't know they have total control over the computer. It's only a matter of time before someone realizes their power. Linux sux 4 me.
I remember that issue on 12.04.
http://askubuntu.com/questions/190959/password-problem-after-creating-a-new-user
I'm not advanced enough to know why.
Hmm... just tried installing some software, that Windows detected I needed .net 3.5 and offered to download it. Failed. Turned on Windows Update, all was fine again. So... it seems a lot of the built in windows download stuff relies on the windowsupdate service.
