Also, I bought one yesterday, and there's like 25 left at the Cambridge, MA stores. Selling like hot cakes.
Here's some pictures taken off Fatwallet.
http://www.pbase.com/arnold25/image/36414536
Got the specs from outpost.com
FEATURES
30" 16:9 Cinema-Style Widescreen Aspect Ratio
HDTV Display Ready (480i, 480p, 1080i, 720p)
750:1 High Contrast Ratio
Wide XGA 1280 x 768 Resolution
High Brightness 700 cd/m2
Dual Built-in TV Tuner
PIP & Picture Grid Views
Digital 3D Comb Filter
HDTV Progressive Scan
170 / 170 Degree Wide Viewing Angles
VGA (DB15) & DVI/HDCP Inputs
Detachable 10W + 10W Surround Speakers
SPECIFICATION
Panels
Active Screen Size (inches) 30" TFT LCD
Aspect Ratio 16:9
Brightness
700 cd/m2
Contrast 750:1
Pixel Resolution (H x V) 1280 x 768
Response Time 15 ms
Viewing Angle 170 (H) / 170 (V)
VIDEO
Digital 3D Comb Filter Yes
Progressive Scan Yes
2:2 / 3:2 Pull Down Yes
Digital Picture Noise Reduction Yes
Resolution Scan VGA, SVGA, XGA, SXGA, WXGA
De-Interlacer Yes
Adjustable Color Temperature Yes
VGA Auto Frequency Correction Yes
TV Auto Frequency Tuning Yes
AUDIO
Surround Yes
Mute Yes
Audio Output RCA R/L preout and Sub-Woofer Preout
Earphone Output Mini - Stereo Jack x 1
Speaker 10w x 2 (Detachable)
Auto Voice Correction Yes
I/O Port
HDTV Input Y/Pb/Pr x 1 (480i, 480p, 1080I, 720p)
Component Input Y/Cb/Cr x 1 (480i)
Composite Video Input RCA x 1
S-Video Input 4-pin DIN x 1
Audio Input RCA L/R x 4
DVI/HDCP Input DVI - I x 1
VGA Input DB15 x 1
TV System Support NTSC
TV Tuner Input TV / CATV RF x 1, NTSC Only
TV System Support NTSC / PAL / SECAM
(Regional Specific)
Service Port RS232 x 1
OTHER
Wall Mounted Type VESA 200, WM-10D / WM-20D
Horizontal Frequency 30 - 80 KHz
Vertical Frequency 50 - 80 KHz
PC Frequency Support 1280 x 768 @ 60 Hz (Max)
Tuner Box Removable for ATSC Replacement
Power Consumption AC 150 Watts (Max)
Dimensions 21.8" (H) x 35" (W) x 8.8" (D)
with Stand
19.5" (H) x 35" (W) x 4.2" (D)
without Stand
28.5" (W) without Speakers
Weight 50 lbs with Stand
40 lbs without Stand
Safety Certification CE, FCC, UL, CUL, CB, TUV
Energy Star Yes
FUNCTION
TV / Video Switch Yes
Dual Tuner* Yes
Channel Return Yes
MTS Yes
PIP / Split Screen / POP 3 / POP12 Yes
Viewing Aspect Ratio 16:9, 4:3, Zoom
Clock / Alarm Yes
Sleep Timer Yes
Favorite Channel Yes
Setting Yes
V-Chip Parental Control Yes
Close Caption Yes
Language English, French, German, Italian, Spanish, Portuguese, Swedish, Simplified Chinese and Traditional
FEATURES
SPECIFICATION
Panels
Aspect Ratio 16:9
Brightness
700 cd/m2
Contrast 750:1
Response Time 15 ms
VIDEO
De-Interlacer Yes
AUDIO
Surround Yes
Mute Yes
I/O Port
VGA Input DB15 x 1
(Regional Specific)
OTHER
with Stand
without Stand
Energy Star Yes
FUNCTION
Dual Tuner* Yes
Channel Return Yes
MTS Yes
Clock / Alarm Yes
Sleep Timer Yes
Setting Yes
Close Caption Yes
