are my temps good?
peewee
i think i am giving up on getting lower temps, right now i am at 39-40c at 1.62ghz, i only have 1 case fan, but i have 5 120mm panaflows on order to install later..so i was wondering if 39-40c is good for my watercooled setup.. also one of these days im gonna mount my pump outside of my reservoir to kill the heat te pump adds to the water....
Well your on the rite track, getting better case cooling and moving your pump out of the water, you may be able to get temps down a little farther though, try making one of the bong type evaporative coolers to chill your water some, if your stable at those temps i would not worry about it but i always strive for cooler temps. all in all your OK but allot depends on ambient temps
goodluck
