- Dec 19, 2000
- Stockton Cal, USA, Earth
When I got my hot little cCO 700E, I took my alpha off my 600E, and when I took it off, I noticed that it (A.S.) had discolored...and I didn't have it on there but a couple of months, and now a freind had his cpu start to get too hot, and regreased his cpu (he is using A.S. as well) and the problem went away...have any of you had to "redo" your proc? and have you noticed the discoloration?
I am starting to think that about every two or three months, we should reaply the stuff, or at least inspect it.
So if you notice that your temps are rising (and not from the summer heat) suspect your A.S. compound.
Maybe Ed or Joe could take a survey on the subject...I think it might be worth while.
