- Nov 1, 1998
Today we look at ASUS' top of the line AMD board, the Crosshair V Formula. The Formula houses AMD's newest chipset, the 990FX northbridge and SB950 southbridge.
Input is certainly welcome. I'll bring your post to ASUS' attention and ask if there are any known issues.
Did your RMA'ed board function properly?
EDIT - Can you link to your issue and similar issues at the RoG forums? I'd like to be thorough if I do email them.
I mean the replacement board you received; did it function properly? Or did you RMA to the vendor and get that UD7 in your sig?
I won't bother my contact about it then; if Raja notified them, they know.![]()
I'm reviewing the UD7 now. Good, solid board. It's a very tough decision between the two. Likely a tie all told, depending on what feature set you need. They're similar, but different such that they offer significant enough differences to meet the needs of two distinct audiences.
Better stop before I preemptively write my own conclusion.![]()
