newer si sandra reconizes it. i had same question with my at7. crazy huh. ignore it. now to ram settings....i couldnt get aggressive with my ram either (768mb of pc2700 samsungies), until i put volts to highest setting (2.85v) didnt know if it was safe or not so left aggressivness alone. i do have cas 2, 4 bank, and 2t access though. but what is even better is a fsb of 175. sweet..........hey, would like to see what the highest fsb you could get with your aggressive settings... would you check please.....having trouble with dram timings and there are so many tweaks in this bios that it aint funny. here's my setup:
at7
xp 1900+ @ 1666mhz (175fsb~9.5x mult.) 1.775v (so far stable, just made this change, will let know how it is working) 47' idle at
51' load with 80' room temp.
768mb of pc2700 samsungies with tt ramsinks (cas 2, 3t-6t-3t, enhance enabled, md and dimms 1 & 2 at high, 2t access and 2t command, 0 for last setting.
geforce 3 ti200 @ 220/460 (stock) well, did add artic silver 3
2x maxtor 60g's @ raid 0
2600'ish on sisandra mem benchmark
8300'ish on 3dmarks 2001se
oh, by the way, i did notice that when i was able to use 1t command that it brought my ram efficiency up alot and sure would like to use it but them darn blue screens and not starting at all is keeping me from using it. so feedback............please.......
