I don't know if I'll be able to give any more than anectdotal evidence of the supply's properties for a few weeks. This is the last week of the semester, crunch time for sure. I'll be graduating May 7, and afterwards I may well get together with my father (a retired big-time TV power supply engineer) and produce some representative data.
The fan controller idea is Antec's. The "fan-only" molex's on the original True Power series is driven from the same controller that drives the supplies' iffy internal 80 and 92mm Top Motor fans. While I dismissed the value of this feature originally, it has proven to have real merit.
Previously I used Mechatronics 120mm case fans running at 12V. These are 25mm thick units that spin at 1500rpm, move 55cfm, and are (realisically) rated for 25dBA. The fan controller circuit on the Antecs really pulls the fan voltage down, and as such requires powerful fans for the realized fan speeds to be in a useful range.
I also find that the stock fans on the TP's spin too slowly for fully loaded operation with this degree of voltage reduction. The 92mm Top Motor OEM fan in my TP430 started making spurious noises not long after I started using it, and since the air leaving the supply's exit would shrink heat-shrink tubing replacing it with something stiffer would seem a natural step.
After trying every fan in the house (50 or so), the best combination turned out to be an 80mm NMB fan from a FSP350-BN (.35A) and a old Pabst 92mm I had laying about (.5A). I also power, from the same circuit via the original "fan only" connectors, two Sanyo 120x38mm fans (.52A ea), and the 45mm Delta (not much current). So in all, I've got about 2A comming off the TP430's fan controller, and it does not seem strained.
It is not safe to assume that the fan controller in, say, an AX500-A is capable of driving this much load. As the fan-only connector is an Antec exclusive, their fan controller may be capable of more current. I haven't analyzed the circutry, but will at some point.
What really surprised me was that using the power supply temperature as the basis for case fan regulation works very well--better than any other temperature dependant scheme I've seen. The Sanyo 120s are quieter at 1385rpm than the existing Mecha's 1500rpm, and ramp up noislessly (other than airflow) to 1750rpm with a instance of Prime95 running. Running 3DMark 2001 to further stress the cpu and maxmize video card power consumption brings them to 1900rpm-with only a very moderate increase in the woosh of the machine.
Certainly not silent, but capable of dealing with the thermal consequences of a relatively advanced performance level. And really nice at idle. The 38mm thick Sanyo still provide good cooling power at ~1300 rpm, and whole lot more effective at 1750-1900rpm than the 25mm Mechas turning their 1500rpm.
