best hsf for.....
the question is not what is the best, it is what do you want to spend?
www.tomshardware.com just did a review on 47 coolers
check that out. Most of them can do socket 7... and your CPU puts out less heat that the test ones toms used...
so anyone that he has a good result with, will be a good choice
