- Sep 23, 2011
I currently live in the Philippines, so the reason I only have limited choices of what router I am able to get. They are:
-Buffalo Airstation N600 (cheapest)
-Netgear WNDR3700 N600
-Belkin N750 Db (Most expensive)
-ASUS RT-N15U (found some more not sure if this on is dual band?)
I currently have a Belkin N router, the reason for upgrading is because I'm told I'll have better connectiviy with a dual band router? We have about 8 devices connected including one wired, but normally only 5 being used at once.
Is it worth upgrading and which of the 3 is best? We live in a 300sq/m house.
If you have anyother suggestion I'll try have a better look around for it. I would like to avoid Linksys by cisco I've heard they recently had some changes with the small print ^_^
Thanks
Thanks
