Hi Again,
For those of you who want to know, I have attached a poorley done image of what I want to evenentually achieve. Basically, its a black MDF box with 5 shelves. The top 3 shelves hold computers (AmigaONE, Apple, IBM). The 4th shelf has the external drives and the 5th carries the power supplys.
The first 3 compartments will have a small window allowing you to see inside. To make it more intereasting the insides are painted wiht UV paint a colour that matches the platform (well, a colour that I think matches the platform.
Blue - IBM
Red - AmigaOne
Green - Apple
The 4th compartment has a flap that covers the drives, and the 5th has nothing.
The 3 computer contain comparments have 2 fans on 2 sides of the case so there is a good clean flow. The 4th has no fans and the 5th contains holes for the 3 Antec power supplies (the ones that glow).
'The OS Box' as I am to call it, is going to aim to have the largest amount of Operating Systems ever contained in a singular case.
Any modifications I should make to my design?
