I recently got a new Biostar TA880GU3+ Motherboard and it has an automatic overclocking program and allows me to OC my AMD Athlon II 270 from 3.4 to 3.9 by changing just one setting in my bios. It also allows me to manually overclock. If I do it automatically my RAM runs at 766 mhz @ 9 clocks. My RAM is 8 gigs of kingston hyperx 1333 mhz supposed to be at 7 clocks. I can change my RAM timings and make it go into XMP mode and it runs at the 7 clocks it is supposed to, but when I try to overclock my CPU manually It ends up running at 3.5 max. Can someone help me get the most of out my RAM and OC my CPU to 3.9 at the same time? Right now I have to pick one or the other and I'd like to be able to do both obviously.
Thanks in advance.
Edit: I found out how to change the RAM to the settings I want and I can change the FSB speed up to 230 from 200, which is what CPU-Z tells me my bus speed is when I do the Automatic Overclock, but when I try this my mobo won't post and I have to clear my CMOS. I have a feeling I'm missing some other setting, possibly voltages?
Thanks in advance.
