- Jul 29, 2011
- Buenos Aires, Argentina
I'm gonna try the v7 miner tonight, if I manage to install my silver arrow with custom 2011 bracket...lol, wish me luck.
This is a really basic probably stupid question but I couldn't find an answer since its so basic. What does the number mean listed before the kh/s in cgminer mean? When I drop from 15 intensity to 12 to watch videos this number drops from around 350k to 200k but the kh/s number stays roughly the same. Wondering how it relates to the amount of coins earned.
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
In catalyst it is only showing the second card. After mining for a couple minutes it was showing 80-81. cgminer was showing the same but also showing 101 for the first card.
I decided to swap the cards on the motherboard. The card in the first slot obviously has cooling issues (thermal paste?). So I figured it would get a little bit more airflow in the bottom slot. It helped the temps so far, now gpu0: 69 gpu1: 83. I'm sure the room will heat up some and temps will rise a bit.
I left out that the case is a Silverstone TJ07 with the side currently off and I'm running Windows 7 Ultimate 64bit.
Also these cards are sucking a whole lot more juice. I have a killawatt and with my single 6950 it was showing ~260watts mining. With the two 7950s its ~680watts at intensity 17. It is higher than I thought.
lol my 6950s fans both just failed too hahahone 7950 both fans failed so RMA here it comes!
Yeah, we're all waiting for it. Might
not make CPU obsolete though... I predict price rising with lesser block reward.
