- Jul 29, 2011
- Buenos Aires, Argentina
Mtgox will include ltc...that will boost it nicely.
thats a huge increase, I dont forsee that anytime soon if at all, thats like btc going for 1k and thats really pushing it, may as well simply buy some btc and wait![]()
mtgox has confirmed they'll put litecoin and other altcoins up in the near* future.
I also don't think $115 is the highest bitcoin will settle to before the year is over
oh not 115, but about 150; about 5 for ltc
btw anyone know why in btc 5770 and 7770 are about same, while in ltc the 7770 sux200 for the 5770 and only 150 for the 7770 with 18 intensity
what is API in BTC-e? im really at a loss here
Moho are you fixing your issues with invalids? Make sure you are on a stratum server and tweak your settings to try to reduce those. You are losing 15% of your hashes to invalids.
Yeah ive tried everything from 15 intensity to 128 worksize, vectors 1/2, 1/2 gpu threads, everything is between 10-15% loss.
thats why I was headbanging after I seen the screen with so low invalids
all are using stratum.what cards are you using? post your current config
I would actually first assume you need more voltage/lower clocks to correct invalids if you're already using stratum and optimal miner settings for the cards
assuming you have a few different cards, do ALL of them have 10-15% stales? or is it some cards and not others
Luckily it's working again...guiminer was really MEH.
I'll run the 7950 till I can get my MVG back to life, then it'll be 6950+7950.![]()
Delete the vector setting as cgminer is plenty good at setting that. The shaders need to be set, so check the readme. Then try multiples of the shader number for the thread concurrency. If it gives an error at start up about memory, you will need to either lower the thread concurrency, or increase the look up gap one at a time until it works. Those settings alone should fix your issues.
