- Jul 24, 2002
- Seattle, WA
Well, I won't say for sure that intake is bad. Hopefully it's not too tough to flip the fans around once everything is installed?
Yeah, I was just going off some suggestions from people on OCN with the same case that got good results like this. Hmm...now you guys got me thinking....
Well, if anything is going to change..the time is now!
Just because you get good results, doesn't mean you can't get better!
I would say it's usually a good rule of thumb to go with the laws of nature and not against them.[/SIZE][/FONT]
The water level looks low from your video. It's going to be hard to work out because there's so much turbulence in the res. Keep filling!Question - I have been tilting the case around trying to get the air out. Should I just let the pump run and let it work itself out?
Is that your silver kill coil/biocide in your reservoir?
so how did you find the difficulty of setting up your first loop? you did quite the professional job, if you ask me...
Great job Stainlineho!
very nice stainlineho, looks good, i hope mine will be as good put together as yours. Can you post up a pic of what the front of you case looks like? I noticed you moved your DVD drive down one slot (or so it looks like from the pics), and if you do then you have to have your dvd drive flush with the front of the case, instead of the recessed insert where you can use the dvd cover. << sorry if that didnt make sense.
I am trying to mod/fabricate something that will let me recess the DVD drive in the second or third bay and utilize the dvd cover for the front of the case.
That's exactly how I was hoping this would turn out. Nice work!
