- Jun 24, 2001
- in the garage
Today I opened up my case to dust the front dust screen on my lian li, and in the process noticed that my CPU fan had fallen off(it was previously secured with electrical tape). My system had been running at ~51C, but it was running alright, so I hadn't thought to open it up.
After screwing the fan on, taping some wires so I could run some case fans at 7V(never invested in a baybus). I put everything back together and hit the start button, and nothing powered on. I checked connections, the power cord, etc, and found that my PSU wouldn't start up manually(using a wire between pins on the ATX connector), so I pulled out an old 250W I had in my closet, which started up fine, manually.
However, once I put it in my case and hooked up my drives and mobo, it still refused to power up using the power button. Neither would it power up by jumpering the power pins on the board! The little green light on my motherboard still isn't lighting up, even though everything is connected. Anyone have any ideas for me to try? The only thing I could think of would be that I shorted the board out somehow, and need to wait a few hours for it to fix itself.
Note: the 400W PSU makes a soft buzzing sound when I try to start it up manually.
