- Mar 5, 2004
- Bedford, Texas
ok we just installed a full stereo in my mom's 96 impala SS and now we are having a couple of problems
the system:
headunit- stock radio from that car, delco electronics cd/stereo that works fine and she wants to keep it "stock looking"
front speakers- infinity INI 6000CS 6 1/2" component http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8868&qp=0&oid=67912&m=0
rear speakers- infinity INI 9603I 6 x 9" 3 way http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8868&qp=0&oid=67917&m=0
sub- infinity INI 1030W 10" http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8871&qp=0&oid=71444&m=0
front and rear amps- a pair of MTX RT202 http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8865&qp=0&oid=62869&m=0
and the sub amp- sony XM2100GTX http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8865&qp=0&oid=86766&m=0
and we put in a optima yellowtop battery
for now only the 2 mtx amps are plugged in and not the sony/sub
ok now onto the problems
1. when you turn they key to accessory the amps turn on and everything works fine but if you start it from accessory mode something pops and the amps wont play until you restart the car.
2. there is a whine from the alternator, we got a tsunami 2 farad cap and put it on there and it didnt help. would we need to use a "noise filter" also?
those are the main problems so far, whenever we get those worked out we're gonna hook up the sony amp and the sub and hopefully it doesnt cause any more problems.
thank you in advance for any help, it will be very appreciated-
~Magick_Man~
the system:
~Magick_Man~
