- Dec 4, 2002
- Thousand Oaks, CA
- Thread Starter
- #41
Thanks ekovalsky.
You know...I really like the external bracket and I actually bought and returned it. I wanted to keep things "inside" the case as much as possible that's why I sent it back.
From the pics below you can see some of the challenges I had with the rad blocking the motherboard headers. Not really a problem b/c the things that are blocked I don't need access to. The fans are 120mm x 25 mm between the grill and the rad.
I had some questions about the Aquastream/Eheim 1046 and it's ability to move enough water. Anecdotally my temps have gone down about 2c when compared to the 1048 under very similar circumstances. I'm just very surprised at the performance of the 6mm ID tubing and the small "low flow" pump. With the evo 360 I have yet to surpass 50c with the Aquastream. Looking back at my temp logs with MBM (mother board monitor) when I was running the 1048 my temps were about 2-3 higher. Again, the little pump that could is doin' it for me.
For my GPU loop and flow sensor I am going to use black tubing, which should look nice. Expecting the new faceplate for the Aquero, which should match the brushed Al in the Lian Li perfectly. I'm also going to do the carbon fiber mod to the drives. Should clean that area up some.
The black sleeved cables go the the two fron USB ports and the other cable links the front Fire Wire port to the mobo. The SATA cable goes to my 3rd back up HD.
