Your welcome, to me that voltage drop seems fishy, as if the Bios is still trying to initiate power savings mode and your frequency doesn't drop, that will cause a crash. You could try changing the minimum proc power to say 20% see if that clears things up for you. Not really familiar with Intel, but any freezing or crashing is bad for components. Hope you get it resolved.
You're definitely right. And I think I'm close to solving the problem. Or at least that's what I think.
Tomorrow, I'll delete the ai suite (computer froze without this too, but perhaps disabling c state AND deleting this will disable all power saving options), and look for more power saving utilities of my motherboard to disable.
And then, I'm going to set a manual voltage to my cpu, something along the lines of 1.2 - 1.25 and try to stabilize the system. I don't want my system's core voltage to change, ever. I'm not going to OC the cpu, just going for stability here. I will let all of you know. Also, here is a list of the things I've tried so far, so that people can see how annoying the problem is, and how troubleshooting such problem is tedious.
Change my motherboard (it was maximus VIII Gene, and I upgraded it to formula and nothing changed)
Change my Power supply (it was another corsair 850w, and nothing changed)
Change my OS (it was win7, upgraded it to win 10 just to see if it would change anything. It didn't)
Changed HDDs all around (no combination worked, I tried all, even bought a new ssd)
Took it out of the case and placed it on a cardboard box to check if the issue was the case components. It wasn't, nothing changed.
Put my old GPU back (gtx 680) and it STILL happens.
Disabled network adapter, used a usb one. No change.
Disabled c-state, no change. (though this one should be done to achieve stability in the end I think)
Updated Bios.
Tried multiple GPU drivers.
Updated every motherboard driver there is (most of them have only one)
Changed my external audio card. Also, did nothing.
Two components I have not touched are RAM and CPU. But I've ran two memtests on the RAM and they seem error free. That leaves us the CPU, but I still think this is not a complete hardware issue but rather cpu combined with motherboard settings (default settings I mean) not playing well. Hopefully I'll fix it, with help of many others here.
I'll keep everybody posted of my findings.
