- Apr 6, 2001
- Mount Vernon, WA
I have a p2 400 clocked up to 600 @140fsb 2.3v (i know dont say anything, i cant afford a new processor) and i have a water cooling system with a 150watt pelitier (a little overkill) and i live in humid washington state. currently my peliter isnt on the processor, only the water block, cause whenever i use the peliter for an hour or more i get the bsod in windoze and i open the case to see whats the trouble and my processor is soaked in water (probably the 0c cpu temp, hehe) i know its deionized water so it wont short curcit anything but it freaked me out, ive tried covering my processor in the so called no condensation gel, but it doesnt work, how can i avoid this problem again, cause i wanna use my pelitier with no moisture. would i just like cut out foam to put arround the processor or what?
