Here is the cpu support list for your mbo:http://www.cpu-upgrade.com/mb-ASUS/P5KPL-CM.html
So,you can put any of the core 2 quads or core2 duos.What is your budget,and what gpu and psu do you have?
Just make sure you flash to the latest bios to make sure w/e chip you select from that list is compatible. Also b/c of the chipset (G31), you will likely not be overclocking anything very far, especially not a quad core.
If you really wanted to you could get a used Q6600 for around $130 and sell that e6600 for about $60. Not an amazing upgrade but it would suffice for another year or so.
If you have 4 gigs of memory already, don't bother adding more.
