16000? Fastest ram ever!
Any luck yet?
whoops.... I wish I had some ddr3-16000
No luck
Just won't boot when I raise the BCLK. Doesn't help that every time it fails, I need to reset the CMOS, and do ALL the settings again. The CMOS reset button (and the battery, too) is hidden under the graphics card so I have to take that out, hit the button, reseat the graphics card... such a pain
From MIAHALLEN
ress the power button rapidly 4 or 5 times...she starts right up . Okay start slow change your bclk to 137 then up by 3 till it wont boot. You have a good X58 board capable of 200+ bclk unless it defective.
Fill in this EVGA Bios Template with your current settings and post back we will get your mem sorted out.
Mother Board ( EVGA X58 X3 SLI )
Drivers ( )
Bios ( SZ1N )
CPU ( 965EE )
CPU Cooler ( Danger Den/water )
Memory ( OCZ Gold 1600 8 8 8 24)
PSU ( Thermaltake Toughpower 1200 )
GPU ( GTX295 X 2 )
Drivers ( 181.22 )
Operating System ( Vista 64)
Frequency Control
CPU Clock Ratio ( 24X )
CPU Host Frequency (Mhz) ( 133 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Control Setting (Enabled )
Memory Frequency ( Auto )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( Auto )
tRCD Setting ( Auto )
tRP Setting ( Auto )
tRAS Setting ( Auto )
tRFC Setting ( Auto )
Command Rate ( Auto)
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( Auto )
CPU VTT Voltage ( Auto )
CPU PLL VCore (Auto )
DIMM Voltage ( Auto )
DIMM DQ Vref ( +0 )
QPI PLL VCore ( Auto )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
ICH VCore ( Auto )
PWM Frequency ( 800 )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Enabled )
Virtualization Technology ( Enabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
