- Mar 7, 2008
A long time question I've had was what performance does the quad channel ram really give you. I've worked out a model so I can predict it, but that's obviously not the same as trying it for real. I'm debating setting up a low cost 5820k box to test it out, and I'm working out the economics of it now. It would help to know some things:
What's the typical voltage at stock? (3.3 GHz)
What's the typical voltage at say 4 GHz overclock?
I found an Anandtech review where they were running 5960X at 3.5 GHz at 1.0v, and for two samples at 4 GHz, 1.074 and 1.197v. So a bit of variability there.
Are the budget X99 mobos actually useful for overclocking? Bare in mind I'm not going for absolute highest clock speed at high voltages. I would be targeting 4 GHz+ at lowest possible voltage.
I know, "budget" and X99 shouldn't really be used together but this would be purely a cruncher.
