Different types of Neoprene
BrianH2O
What is the difference between High-Grade Neoprene Rubber and Commercial-Grade Neoprene Rubber?
Is Commercial-Grade Neoprene Rubber acceptable for insulating a chilled systems? It is like 1/3 the cost of High-grade!
Also, what ShoreA value am I looking at? I would presume, the softer the better, ie 30A.
B
BrianH2O
Bump and some more info from McMaster-Carr
Part Number 8461K615 $15.58 Each
Form .................... Sheets
Material ............... Neoprene
Neoprene Material Type
Durometer ............ 30 Shore A
Type ...................... Adhesive-Backed
Length ................... 36"
Width ..................... 6"
Thickness ............... 1/4"
Tensile Strength ..... 1000 psi
Elongation .............. 400%
Specifications .......... ASTM D 2000-86E, Type BC
Operating Temperature Range
......... -30° to +200° F
Temperature Range (Adhesive)
.........-20° to +220° F (Pressure-Sensitive Acrylic)
Color ......................... Black
Thickness Tolerance ± .031"
And ---------------------------------------
Part Number 8456K155 $32.69 Each
Form ..................... Sheets
Material ................. Neoprene
Length .................. 36"
Width .................... 6"
Thickness .............. 1/4"
Tensile Strength ... 1200 psi
Elongation ............. 400%
Specifications ......... ASTM D 2000, Type BC and MIL-R-3065
-40° to +212° F
-20° to +180° F (Pressure-Sensitive Acrylic)
Color ........................ Black
Big diff in price. What is the difference other than Tensile Strenght? Would the Commercial-Grade Neoprene Rubber be OK to insulate with?
Dissolved
OC California
Well as you see the 8456K155 holds up to 1200psi, and to -40C. if your just useing a pelt, then then 8456K115 will do you ok i believe.
