do i need a new psu for my new gpu or will my current psu work
kaitlin4599
ok so i decided to buy a new in box saphire RX 470 heres the link
https://www.newegg.com/Product/Product.aspx?Item=N82E16...
how many watts do i need for the psu and how many amps on the 12 volt rails heres my specs
XEON W3565
475 WATT PSU 38 AMPS ON THE 12 VOLT RAILS 1 6 PIN PCIE POWER PLUG BUT I ALSO HAVE A 6PIN TO 8 PIN
6X 4GB DDR3 RAM THANKS
below is a link to my power supply. if i need to upgrade the psu please tell me how many watts i need as well as how many amps on the 12 volt rails thanks
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01709672#N10081
caddi daddi
Godzilla to ant hills
you're good to go it's a 130 watt cpu and about the same for the gpu so 250-300 watts should be the worst case draw.
Nebulous
Señor Senior, Senior
The Empire State
Not sure what brand of power supply you have tho, so it can be underrated. A quality branded power supply like EVGA or Seasonic in a 500w flavor will do you right.
trents
Senior Member
The PSU should be adequate as long as it isn't failing or something.
