*SUCCESS*
I was too antsy, so I went ahead and tried this on my XP1700 T-bred B. First, I just shorted the last L3 bridge. Booted up... nothing. Ok, I figured I had to hard code a certain multiplier in, so I looked at the T-bred painting guide
here and saw that if I broke the 3rd L3 and the last L3, then I would be coded for 13X. I took off the CPU, shorted the third L3, put the CPU back in and VOILA, 13X! I don't have any options for multipliers in the BIOS, except 5.5-12.5 (if I choose any of these multipliers, the system won't boot.) This may be an issue with my motherboard, or it may be a limitation of the procedure.
I'm so happy I didn't kill my CPU! I'm even more happy because I may be able to overclock this chip higher. My Shuttle AK35GT2 is a KT333 chipset board, but seems to be missing the 1/5th divider, so I can't run it much faster than 155 FSB, or my hard drive corrupts. It won't even post at 166 FSB, with lowered multiplier.
Anyway, bottom line is, YES, you can blow the bridges on T-breds using 5V supplied from a PSU as explained here -
http://www.overclockers.com/tips726/.
I tried with a 9V battery and it wouldn't work. PSU 5V did the trick, though. *EDIT* I used an old AT PSU, BTW. I find it a lot easier to work with a PSU with a power switch, and if I killed the PSU, I wasn't out of anything.
I have not tried this on XP1800's or on my K7D Master, yet. Also, be aware that blowing only the last L3 bridge does not seem to open all of the multipliers above 12.5, at least not on my Shuttle AK35GT2.
Many thanks to pctuner@amd for turning me on to this procedure.
