Hello. I am new to performance hardware and I just recently built my first gaming machine. I guess I'll start with my rig. I'm not really sure what info you guys need, so if I leave something out let me know.
MB: MSI 760GMA-P34 FX
CPU: AMD FX 6300 6 core @ 3.5ghz
GPU: MSI R9 270X Hawk
RAM: 8gb DDR3
OS: Windows 7 Ultimate 64 bit Service Pack 1
Ok, so I got it all put together about a week ago, and started up Skyrim with everything turned all the way up. Ran great. Felt like a consistant 50-60 fps at all times. Over the last few days I've thrown on a few mods that made the performance drop, so I thought I'd look into overclocking. My cpu specs say 3.5ghz (4.1ghz turbo). I take that to mean that it can go up to 4.1ghz safely. And everything I read about my gpu says that it's built for overclocking. It even has that afterburner software that lets you slide some levers to easily do so. The biggest danger that I gathered from what I read, is overheating, so today I installed a couple more case fans. I ran my cpu through the overclock testing that's built into the catalyst control center, and I let it test up to 4.1ghz, and the temp never went above 42. I turned it down to 4.0 to keep from pushing it to what I presumed to be it's advertised limit. I used the afterburner sliders to turn my gpu core clock all the way up to 1400 and the memory up to about 1700. I threw the hardware monitor up on my second monitor along with a little app called speedfan (basically just a hardware monitor), just to make sure the temps I was seeing were correct. I booted up Skyrim with some tasty mods. and I could tell immediately from the animated loading screen that the game's fps was very unstable. And before the game could finish loading I got a blue screen crash. I immediately rebooted and turned off all overclocking, and turned off all Skrim mods, restoring it to what before was a steady 50-60 fps state. But when the game loaded, the performance was terrible. the framerate was well below 30 fps, and there was awful input lag. I double and triple checked that I had restored all overclock settings back to default and turned off all mods, and I hadn't forgotten anything. All settings were exactly the same as they were when I first played, but the game ran just awful. I guess I should note that I haven't noticed any issues outside of the game in case that's helpful.
So, did I damage something? Would a fresh driver reinstall fix this? Maybe a windows reinstall? Any ideas at all about what I could do to fix the situation?
Thank you for your help!
RAM: 8gb DDR3
