- Sep 23, 2001
- In your head (Ottawa.Canada)
Ha...got your attention!
I attempted a duct sset up in my 1.4 rig and it was pretty "Ghetto" as the term goes. Basicallly I was trying to get air from the fron bay fans to my cpu by the most direct route possible. I am very unfamiliar w/ the duct concept..though it sounds simple enough. My question is this..if I swap my Hard drive fans for a 80mm case fan and rig a tube from it to my cpu..will this provide better cooling? It seems to me that the duct is usually just a tube that connects to outside of the case so the cpu is sucking direct air from outside. I am not sure of whether peeps have a fan helping the flow of air to the cpu...in theory it seems sound..is it?
My results w/ a cardboard tube gave me a 1 degree drop in temp and made a awfull whine sound that told me it was not worth it.
My temps on my 1.4 t bird are 50c at full load....I added some insolation to sides of the case to cut down on sound and that adds to the case temps, but I figure w/ 2 hard drive coolers(5fans in 2 empty bays) blowing in cool air straight across to the cpu and 2 exhaust fans (one on level w/ the cpu and the P/S exhaust above cpu) that my temps should be alot better....is the Volcano 7 a poor performer(steady at 5100 rpm's) or is my fan placement poor?
