- Nov 22, 2003
- New York City
You won't have journaling when you mount ext3 under Windows, but at least the journalling will be back when you remount in linux. I thought that ext3 was more or less just ext2 with journaling? (thinks back to mke2fs -j)
The driver is great, I've been using it for a while now. I like the fact that I can unmount the drive in Windows (so that the drive won't appear on startup.)
The gotcha is that if you mount an external ext2 drive in Windows as drive X:, but forget to unmount it before you remove the ext2 drive (shut down, reboot)... when you boot back up, the X: drive will still appear under My Computer. Simple uninstall/reinstall of the driver fixes it.
Once in a while, some Windows application won't like the drive. I can't remember which proggie hiccupped with my ext3 drive. Still, all in all a great driver.
However, there's always the possibility of a windows virus running over your now accessible ext2 data... so I suggest, if possible, to only have the drive mounted when you use it, and unmount it when you're done. I don't think there's a worm/virus that mounts possible ext2 drives just to wipe 'em out.
