Good evening.
Long time folder, first time posting at your site.
Background: For the past several years I have been folding for Bjorn3d and am currently right around 47,000,000 points. I am getting ready to change teams and was hoping to join Team 32. Unfortunately, I have been having a problem that I can't seem to fix. I run three, older machines in my farm: A) i5-3470 w/ gtx 470, B) i7-950 (OC 3.9) w/ gtx 470, and C) q9550 (OC 3.6) w/ gtx 460. A & B run Win7 64bit and C is still chugging along on Vista 64bit. Generally, in early summer to about the first of November, I use the machines to render video so I shut down the clients. After the rendering time is over, I always do clean installs of the OS on the machines - just a habit, not sure why I do it. A problem arose after installing v7. None of the three machines can "read the stream". Copy of the log for one of them is below but it is similar on all three. What's odd is, I can fold on all three machines using the CPU only through the Chrome app. The results are not bad but I would like to get the GPU's up and running. I have an i7-2600k (OC 4.6) w/ gtx 670 ready to replace the q9550 but, until i can get this cleared up, there is no sense.
For the past two weeks, I've been reading all the postings I can find that discuss this issue but still can't quite get everything to work. I know any work is good work when it comes to folding but I would love to have everything running on all cylinders.
I could not get the log to show properly so I just copied a portion of it below. Sorry about that.
*********************** Log Started 2014-11-18T19:38:23Z ***********************
19:38:23:************************* Folding@home Client *************************
19:38:23: Website: http://folding.stanford.edu/
19:38:23: Copyright: (c) 2009-2014 Stanford University
19:38:23: Author: Joseph Coffland <[email protected]>
19:38:23: Args: --open-web-control
19:38:23: Config: <none>
19:38:23:******************************** Build ********************************
19:38:23: Version: 7.4.4
19:38:23: Date: Mar 4 2014
19:38:23: Time: 20:26:54
19:38:23: SVN Rev: 4130
19:38:23: Branch: fah/trunk/client
19:38:23: Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:38:23: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:38:23: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:38:23: Platform: win32 XP
19:38:23: Bits: 32
19:38:23: Mode: Release
19:38:23:******************************* System ********************************
19:38:23: CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
19:38:23: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
19:38:23: CPUs: 4
19:38:23: Memory: 3.90GiB
19:38:23: Free Memory: 1.68GiB
19:38:23: Threads: WINDOWS_THREADS
19:38:23: OS Version: 6.1
19:38:23: Has Battery: false
19:38:23: On Battery: false
19:38:23: UTC Offset: -5
19:38:23: PID: 4640
19:38:23: CWD: C:/Users/TRFB2/Documents
19:38:23: OS: Windows 7 Home Premium
19:38:23: OS Arch: AMD64
19:38:23: GPUs: 1
19:38:23: GPU 0: NVIDIA:2 GF100 [GeForce GTX 470]
19:38:23: CUDA: 2.0
19:38:23: CUDA Driver: 6050
19:38:23:Win32 Service: false
19:38:23:***********************************************************************
19:38:23:<config>
19:38:23: <!-- Folding Slots -->
19:38:23:</config>
19:38:23:Connecting to assign-GPU.stanford.edu:80
19:38:44:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:38:44:Connecting to assign-GPU2.stanford.edu:80
19:39:06:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:39:06:Trying to access database...
19:39:06:Successfully acquired database lock
19:39:06:Enabled folding slot 00: PAUSED cpu:2 (not configured)
19:39:06:Enabled folding slot 01: PAUSED gpu:0:GF100 [GeForce GTX 470] (not configured)
19:39:10:16:127.0.0.1:New Web connection
19:39:15:24:127.0.0.1:New Web connection
19:39:22:Set client configured
19:39:23:WU00:FS00:Connecting to 171.67.108.200:8080
19:39:23:WU01:FS01:Connecting to 171.67.108.200:8080
19:39:23:WU00:FS00:Assigned to work server 171.64.65.79
19:39:23:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.79
19:39:23:WU00:FS00:Connecting to 171.64.65.79:8080
19:39:23:WU01:FS01:Assigned to work server 140.163.4.231
19:39:23:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF100 [GeForce GTX 470] from 140.163.4.231
19:39:23:WU01:FS01:Connecting to 140.163.4.231:8080
19:39:24:WU01:FS01ownloading 4.83MiB
19:39:24:WU00:FS00ownloading 250.56KiB
19:39:25:WU01:FS01ownload complete
19:39:25:WU01:FS01:Received Unit: id:01 stateOWNLOAD error:NO_ERROR project:13000 run:972 clone:0 gen:64 core:0x17 unit:0x00000077538b3db75310ae1e24998dcd
19:39:25:WU01:FS01ownloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah
19:39:25:WU01:FS01:Connecting to web.stanford.edu:80
19:39:25:WU00:FS00ownload complete
19:39:25:WU00:FS00:Received Unit: id:00 stateOWNLOAD error:NO_ERROR project:10424 run:4083 clone:2 gen:2 core:0xa4 unit:0x000000030a3b1e734ccfa2ba7ab4ef1b
19:39:25:WU00:FS00ownloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:39:25:WU00:FS00:Connecting to web.stanford.edu:80
19:39:46:ERROR:WU01:FS01:Exception: Failed to read stream
19:39:46:ERROR:WU00:FS00:Exception: Failed to read stream
Thank you,
Paul
19:38:23: Bits: 32
19:38:23: CPUs: 4
19:38:23: PID: 4640
19:38:23: GPUs: 1
19:38:23: CUDA: 2.0
19:38:23:<config>
19:38:23:</config>
Thank you,
Paul
