Fan on NB: size=?
Cereal Killa
Antwerp, Belgium
Hi all,
I was wondering what size would a fan need to be to fit on the stock heatsink on a P4C800 - Dx?
I don't want to use a large fan which comes over the edges to much.
And how to you attach it? (but not with an adhesive which won't allow to come of easy ;) )
Thanks,
Cereal
The fan either balanced or not vibrates some, this with the heat of the HS will probably weaken the glue after a while. Depending on how much heat there is.
WOW!
Now that thing sure would tame a seriously hot NorthBridge!!
I use Zalman's passive HS (gold square one), this with a 92mm tornado blowing over it keeps my NB nice & cool.
