- Aug 3, 2002
- Marrietta, GA
I will be using a thermaltake smart case fan as a CPU fan. I was wondering whether or not to use the 3-pin setup and hook it to the motherboard for monitering, etc. or to use the adapter and plug it into the PSU. The fan will pull about 4.5 Watts on it's highest setting. I am using a Biostar Nvidia 2 M7NCDP motherboard. So in short:
-Should I use the fan on the Mobo or PSU?
-If it depends on the Mobo, where can I find the information? In the manual?
Thanks again for all your help
