KILLorBE (Jun 21, 2001 10:40 a.m.):
A few months ago I read an article about unlocking a PIII (It was written by a scientist or an Intel insider) but that was way over my head, all I could make up from what he was saying: IT CAN'T BE DONE BY YOU OR ME (unless you have the right equipment, but that would cost you lots of money I'm talking about 100.000's of dollars).
I've seen one good answer so far (it has to do with frequency), well at least that is what the scientist/Intel insider was saying.
All I know it CAN be done with a SLOT1 PII (They have done it in Germany), but I doubt it can be done with an FCPGA.
A little explanation would be appropriate: A EPROM can be programmed, A CPU (FCPGA) can be programmed as well (They have a built-in EPROM in which the multiplier is set (or something like that)) but there's no EPROM programmer YOU and ME can afford that has a 370 socket.
I hope this makes some sense.
BTW: Nice keychain you have Kingslayer ^_^ (Sorry it didn't work, but I've learned to do some research before trying and not jump into things PPL are saying just because they wanna see if it works).
Maybe i should have posted this a long time ago, but i've been searching for that article........no result yet.
It can't be done! It can't be done because the multiplier is set by burning connections into inside the chip. I believe this is done with a laser. So, once the connections are burnt there's no connecting them back.
As for the PII you saw that was unlocked that's easy to explain. First of all, early PIIs weren't even locked to begin with. I have an old PII-233 that isn't and many other people have PIIs that weren't it was later on that they started locking the multipliers. They did it because unscupulous vendors were remarking CPUs and selling them to unsuspecting customers as faster CPUs. Anyway, when they did start locking the multipliers was about the time the 100Mhz FSB deschutes core PIIs started coming out. At that time the multiplier was locked, not inside the chip, but on the little printed circuit
board that a slot1 chip is located on. This is why it was possible to unlock those. However, by the time the PIII (Katmai) came along they were locking the multipliers inside the chip itself by burning circuit in to. Once those connections are burnt in to there is no connecting them back together. So, once the multiplier is locked this way, it's forever locked for the life of that particular chip.
It's interesting that you bring up Eproms. Eproms are eraseable programmable read only memory. That is they can be progrmmed then later on erased and programmed again. However, there are also what is known as Proms. Proms are Progrmmmable read only memory. That is they can be programmed, but only once, and after that they cannot be erased or reprogrammed. The way they work is kinda like blowing fuses inside the chip and burning connections in to. If you've ever seen a blown fuse then I'm sure you can understand that they cannot by any electrical means be put back together. This is kinda like the way they lock the multipliers except that instead of using a current to blown the fuse they use a precise laser to burn it into. They use the same technique to disable the addition a cache in a celeron II.
Don't believe anyone who tries to tell you they can unlock a locked PIII! They're either lying, badly mistaken, or trying to perpetrate somekind of fraud. It's true there are chips called engineering samples that do not have the multiplier locked to begin with. These aren't really meant to be released to the general public and are for testing purposes only. That's why they are left unocked. These will be marked "Intel Confidential" and the people these are given to are not suppose to release them to the general public, but ocassionally a few get through. Anyway, don't ever send any money or your CPU to someone making such claims and promising to unlock your locked CPU. If you do you'll never see your money or CPU again!
