I was fed up with the hassle of watercooling for a while, then I tried a little bit different approach, I grabbed a 80mm radiator and a c-systems pump and routed 1/4"ID tubing throughout, the system is so small and easy to take care of, I have the 3/8ID pushfits and that makes everything very easy. I plan on grabbing a bix to go along with the case and make things a lot more compact.
Give it a break for a while, if your running a 1/2" system I can see how you can be easily fed up with it. 1/4" ID system seems really small, but if its done correctly the small performance loss if any is well worth it.
Jon
Jon
