Ran some tests with the 4.3Ghz @ 1.18V and compared at least to some results I had for the 4.7Ghz, I was anywhere from 5-8% slower in cpu benchmarks I ran. Only one of the video encoding ones at 4k ended up 10-11% slower. Though for a 9.3% reduction in clock it wasn't that large of a hit performance wise, I'll have to run some gaming benches I had to see if there is really any reduction. Temps where running great, at a whopping 56C maximum under stress test. So its looking like if I want another 100Mhz, I basically just give the CPU another .05V and let her go all the way up to 4.7Ghz. Might see if I can drop it a little lower voltage wise but I think I'm probably pretty close to the limit for stable voltage at 4.3Ghz. BTW my VID voltage is 1.179x (got a screen shot of it saved at home).
kenrou has a decent chip.
For me."decent"... latest BIOS 2202 /w uncore 1:1
4.4ghz 1.2v Aida64 - Realbench
4.5ghz 1.24v Aida64 - Realbench
4.6ghz 1.29v Aida64 - Realbench
4.7ghz 1.34v Aida64 - 1.38v Realbench
4.8ghz 1.39v Aida64 - 1.42v Realbench
Before BIOS 1701 (or was it 1501) 4.8ghz was off-limits and every voltage was .05v above what is now, 4.7ghz and 4.8ghz lowered again by .02v in 1901. I know that Skylake is "sort of" new tech but didn't expect so much tweaking, My Hero VIII had something like 15 revisions
it's not top 20, it's top 20%. It's ambient cooling, not sub zero Canadian air across a rad either. Benching stable, even for xtu, and Realbench for an hour stable are also dramatically different things as you know.According to them, Deatman has one tha'll do it on air, kenrou has a decent chip. I can't attest for normal cooling but mine did 5.2 @1.42v on cold water XTU bench.
Maybe I'm off but I honestly think that's slightly above average not just top 20.
Show me one at 4.8 with 1.25v or less and maybe I'd shell out the premium.
?If you lower the CPU core voltage will that cause damage or degradation of the CPU, Also want to know if lowering the core voltage will increase the AMPs? And the answer is yes from Intel. https://communities.intel.com/message/425662#425662
god now i feel crappy about how bad my chip is.
4.5 stable at 1.312
4.6 stable at 1.344
couldn't get stable above that
To lower temps.1.2v is supposed to be stock for 6700k, is there any merit in going below that ?
To lower temps.
Stock voltage can be lower or higher than that. Every chip is different.
As I sit and peck this out on my phone, I feel like I am adding details for little reason though, lol!
I posted it here because deathman wanted to see how low he could run the Vcore. There is a finite balance when setting the voltage according to clock speed. Increase the voltage there is less AMPs at the same clock speed. Decrease voltage increase the AMPs at the same clock speed, also half to factor in resistance. Basic electronics ohm's law.
That is the true "stock" voltage of a 6700k or what its supposed to be at? I know there are swings in it but always nice to see I can get higher speeds just under or just above stock.
Brings me back to my old I7 920 running it at or below my stock voltage at a higher clock. Really the only merit of staying at or going lower is you got a really nice chip that has overhead. Now it might not mean you can OC it really fast but it at least means it has the potential to be cooler than others. At least thats what I've experianced in past chips that can OC decently at or under "stock" voltage.
