Hello,
So, I have been trying to get my RAM to achieve the highest speed my motherboard (AsRock Taichi Ultimate Z390) can support (4200 MHz or 4133Mhz). I have an Intel Core i9 9900k processor. I own the:
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel XMP 2.0 Desktop Memory Model F4-3200C16D-16GTZR
I have been doing some tests and am at a bit of a blockage for my lack of experience. I managed to get the XMP Profile to show stability with no errors at 3200 MHz 16/18/18/38, but I want to do much better than that.
I was able to POST with 3466 MHz 16/18/18/38 at 1.35V DRAM, 0.95V VCCIO, 1.05V VCCSA, but I get memory errors/lack of stability.
I was also able to POST 3733 MHz 17/19/19/38 at 1.365V DRAM, 1.1V VCCIO, 1.2V VCCSA, but I get memory errors/lack of stability too.
I have been yet to get the computer to boot any speed greater than 3733 MHz, which is substantially under my objective of 4133 MHz or 4200 MHz... What are some tips for me to get stability at these higher clock speeds? I added Voltage to the points I felt comfortable with gradually, but it never booted.
Additionally, 3466 or 3733 isn't listed as supported on my mobo, so why does it boot at all?
Finally, what's the best method for lowering CL speeds from a testing perspective? For the frequency, I have been applying the minimum voltage necessary to achieve stability and gradually increasing the speed, but CL speeds feel like I'm missing a "method" to optimize them.
*I am using OCCT for my testing.
Thanks, AstroCEO.
Thanks, AstroCEO.
