Hey guys,
I finally pieced everything together for my water cooling setup. I am "upgrading" from a CM hyper 212 that has a noisy high cfm fan on it. The goal was a quieter alternative that works as well or better. This was an absolute budget build. Im a poor college student that just built a new rig like 2 months ago.
I used a fleabay 2pgm 5m head pump. I got a danger den res, 94 exploder trans cooler (I think its the source of my problems), 3/8 fuel line, and what i suspect is the water block from an 880 bigwater kit. Not too bad, but obviously not the best.
With my last setup on air, I was P95 stable on blend for at least a couple hours while staying below 52 degrees. With my new WC loop I ran P95, the temps jumped from 28 to 44, then slowly crept up 53, 54, then I stopped it. I ran it another time and I errored out on the #3 worker, what I think is temperature related..
Soo, my question is.. What do you guys think the weak link in the system is? I suspect the transmission cooler is the problem, Im thinking about a heater core or an actual WC radiator.
