BCCode 116 is Graphics. Make sure you have the latest Nvidia driver 331.82. Also make sure your GPU isn't overheating just incase but I highly doubt it.
Yeah I got 331.82. GPU temp is at 45 degrees and power is at 11.5% TDP
When I run a Furmark Benchmark
I get a crash withing a few seconds
This is what the log looks like
<->[NORMAL]#00000001#Sat Nov 23 03:59:52 2013#FurMark 1.12.0.0 is starting up...
<->[NORMAL]#00000002#Sat Nov 23 03:59:52 2013#OpenGL renderer (main graphics card): NVIDIA GeForce GTX 680
<->[NORMAL]#00000003#Sat Nov 23 03:59:52 2013#OpenGL version detected: 4.4
<->[NORMAL]#00000004#Sat Nov 23 03:59:52 2013#OpenGL max viewport size: 16384X16384 pixels
<->[NORMAL]#00000005#Sat Nov 23 03:59:52 2013#Device ID string (main graphics card): PCI\VEN_10DE&DEV_1180&SUBSYS_83F11043&REV_A1
<->[NORMAL]#00000006#Sat Nov 23 03:59:52 2013#CPU/System info:
<->[NORMAL]#00000007#Sat Nov 23 03:59:52 2013#- CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
<->[NORMAL]#00000008#Sat Nov 23 03:59:53 2013#- CPU speed: 3400 MHz
<->[NORMAL]#00000009#Sat Nov 23 03:59:53 2013#- System memory: 16321 MB
<->[NORMAL]#00000010#Sat Nov 23 03:59:53 2013#- OS: Windows 7 64-bit build 7600 [No Service Pack]
<->[NORMAL]#00000011#Sat Nov 23 03:59:53 2013#Detecting GPUs...
<->[NORMAL]#00000012#Sat Nov 23 03:59:53 2013#Found 1 GPUs.
<->[NORMAL]#00000013#Sat Nov 23 03:59:53 2013#- GPU 1: NVIDIA GeForce GTX 680
<->[NORMAL]#00000014#Sat Nov 23 03:59:53 2013# - Cores: 1536
<->[NORMAL]#00000015#Sat Nov 23 03:59:53 2013# - Memory size: 2048MB
<->[NORMAL]#00000016#Sat Nov 23 03:59:53 2013# - Memory type: GDDR5
<->[NORMAL]#00000017#Sat Nov 23 03:59:53 2013# - TDP: 195W
<->[NORMAL]#00000018#Sat Nov 23 03:59:53 2013# - Bus ID: 1
<->[NORMAL]#00000019#Sat Nov 23 03:59:53 2013# - Bios: 80.04.47.00.2d
<->[NORMAL]#00000020#Sat Nov 23 03:59:53 2013# - GPU temperature: 60.0°C
<->[NORMAL]#00000021#Sat Nov 23 03:59:53 2013# - Graphics driver: 9.18.13.3182
<->[NORMAL]#00000022#Sat Nov 23 03:59:53 2013# - True clocks - GPU clock: 1005MHz - Memory clock: 3004MHz - GPU voltage: 1.100V
<->[NORMAL]#00000023#Sat Nov 23 03:59:53 2013# - GTX 600 series - GPU base clock: 1006MHz - GPU boost clock: 1058MHz - GPU power target: 100.0 % TDP
<->[NORMAL]#00000024#Sat Nov 23 03:59:53 2013# - PState 0 - GPU clock: 1202MHz - Memory clock: 3004MHz - GPU voltage: 0.988V
<->[NORMAL]#00000025#Sat Nov 23 03:59:53 2013# - PState 2 - GPU clock: 1202MHz - Memory clock: 3004MHz - GPU voltage: 0.988V
<->[NORMAL]#00000026#Sat Nov 23 03:59:53 2013# - PState 5 - GPU clock: 862MHz - Memory clock: 810MHz - GPU voltage: 0.988V
<->[NORMAL]#00000027#Sat Nov 23 03:59:53 2013# - PState 8 - GPU clock: 324MHz - Memory clock: 324MHz - GPU voltage: 0.988V
<->[NORMAL]#00000028#Sat Nov 23 03:59:53 2013# - Fan speed: -1%
<->[NORMAL]#00000029#Sat Nov 23 03:59:53 2013# - Fan speed: 1350 RPM
<->[NORMAL]#00000030#Sat Nov 23 03:59:53 2013#no multi-GPU support (1 physical GPUs)
<->[NORMAL]#00000031#Sat Nov 23 03:59:53 2013#GPU monitoring thread started up ok.
<->[NORMAL]#00000032#Sat Nov 23 03:59:53 2013#oZone3D Engine is starting up - kernel build: [v3.3.0 - Apr 16 2012 @ 11:03:16] - codename: Zhadanas
<->[NORMAL]#00000033#Sat Nov 23 03:59:53 2013#oZone3D initialization in progress...
<->[NORMAL]#00000034#Sat Nov 23 03:59:53 2013#oZone3D - OpenGL renderer creation ok.
<->[NORMAL]#00000035#Sat Nov 23 03:59:53 2013#o3RendererOpenGL INFO: OpenGL version: 4.4.0
<->[NORMAL]#00000036#Sat Nov 23 03:59:53 2013#o3RendererOpenGL INFO: OpenGL Shading Language (GLSL) version: 4.40 NVIDIA via Cg compiler
<->[NORMAL]#00000037#Sat Nov 23 03:59:53 2013#oZone3D initialization ok.
Please list all parts you used in your final build.
Asus MAXIMUS V1 HERO Socket 1150 Motherboard
Intel i5 4670k
Asus GTX680-2GB DDR5
Corsair Vengeance 16GB 1600MHz RAM CMY16GX3M2A1600C9R 12000
Corsair TX650 PSU
Seagate Barracuda 1TB
OCZ Vertex 3 120GB SSD
Asus DVD Writer
Corsair 400R Mid Tower Casing.
I have connected the graphic card to the monitor via DVI cable if that makes a difference.
